Домашняя электрическая установка — это сложная система электрических компонентов, которые подают электроэнергию в дом и распределяют ее по различным розеткам, приборам и осветительным приборам.
shed light switch not working
shed light switch suddenly stops working, have changed it twice. power to switch and lights work if bypassed. what is causing switch failure? Not used often
Это хороший вопрос?
Счет 0
1 Комментарий:
Hi @underdog500 ,
How many lights are connected to the switch?
Have you checked that the current rating of the switch is appropriate for the number of lights connected?
Does the switch smell burnt at all?
из
Добавить комментарий
1 ответ
Since it is located in a shed it isn't in a controlled environment like inside a house. Humidity and such play large factors. I would recommend an enclosure like this: https://www.homedepot.com/p/Greenfield-W...
I've installed them before, they're very easy, and your switches should last longer since they'll be more protected. Also, check and sure nothing has been leaking in/on the switch or electrical box.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
william bassett буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 9
За всё время: 327
