Logitech Dual Action — это USB-контроллер для компьютерных игр. Номер модели: G-UF13A.
My controller keeps disconnecting
So basically, I’ve been trying to play games with my controller, and it only SOMETIMES connects, and if it does it’s only for a split second, I think it might be because a bit of the special uhh, whats it called? protective case of the wires is exposed, like the white stuff, it’s from the Kittens I have.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi Joshua!
Basically it means that you need to replace the cable. I would replace it first and see how that goes.
Just get the glue off and de-solder the cable. Make photo’s before you proceed as you need to know which color goes where. It will not be easy to find the cable (part).
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Sorry but that doesn't help much, I have no idea how to do these things, I think I might take it to my step-brother, he knows how to do these things I think, he is currently replacing the loose battery on my 3DS, so Ill ask him about this and see if he can help me.
из
Hi Joshua! Sry for the late reply.. Yes you can ask him to replace it if he is able to find the part.
из
Добавьте свой ответ
Joshua Durbidge буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 12
За последние 7 дней: 17
За последние 30 дней: 36
За все время: 1,259
