Chrysler PT Cruiser — это компактный семейный автомобиль или компактный минивэн с передним расположением двигателя и передним приводом, который выпускался и продавался компанией Chrysler по всему миру в кузовах 5-дверный хэтчбек (2000–2010 гг.) и 2-дверный кабриолет (2005–2008 гг.).
Pt cruiser limp mode
Where should I begin to look for the cause?
This is really strange , my car shifts gears fine until I hit a good bump along the street. Once it hits a couple manhole covers or potholes the dash display flickers once or twice and the transmission stops shifting past second gear. I do not believe this is a mechanical problem because it always seems to happen when there's a few bumps or potholes? Has anyone had this problem and how did you find the issue? Where should I look,it strikes me as an electrical problem?
Это хороший вопрос?
Счет 2
1 Комментарий
Hi,
Get the OBDII port scanned for any fault codes.
This may be a good place to start to find out what is happening when the car is in limp mode.
I've read that some auto parts retail chains in the USA will do this for free
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
as previously mentioned in a comment, get the codes read. In the USA places like autozone and O'Reilly will do this for free. See what it says. The fact that a bump causes it tells me its almost certainly electrical. Loose grounds or plugs are likely culprits. Its going to suck, but you'll need to start chasing wires and double checking everything until you find the cause. Could be electrical connector to the transmission.
Был ли этот ответ полезен?
Счет 2
It is an electrical problem, it starts from the connection that reaches the transmission and sees separating the cables, it is probable that some have been damaged and they are making a short, it already happened to me and I solved it that way, with patience separate and if there are stuck cables, peel them off and tape them
Счет 1
Check the electrical connectors at the pcm and Tom under the hood
Счет 1
I too have a 2002 cruiser. My transmission stopped shifting gears out of no where . I was stuck of stupid until someone suggested that i change my transmission filter (never even heard of it,but yes it has one) once i changed it and the fluid itself. I have not had that problem since
Счет 1
Добавьте свой ответ
Margaret Groot-Koerkamp буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 9
За последние 30 дней: 25
За всё время: 2,016
