Зарядная станция для контроллера PS5 Dualsense.
How to remove the white side plates
The dualsense charging station has white side plates like the Playstation 5 console. I want to paint them black, so I was wondering if there was a way to remove the white plates. There are no visible screws. The whole thing seems to be glued together.
Это хороший вопрос?
Счет 3
1 Комментарий
did you ever find a way?
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
If you turn the charging station upside-down, on the bottom plastic you will see two edges which connect to the inside side and top plastic which is one moulding. Pry the bottom plastic off (it's just clipped) and then undo the screws and the white side plastic comes off.
Был ли этот ответ полезен?
Счет 2
See my teardown over at Dualsense Charging Station Tear Down Guide
Счет 2
So if you want to take the sides off your PS five you want to hold the PlayStation button press down and then up and then it’s off
Счет 0
Добавьте свой ответ
Sulakshan Rajaratnam буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 16
За последние 30 дней: 53
За всё время: 2,179
