Ninja Coffee Bar CF086 — это кофеварка с термокувшином объемом 1,27 л и системой управления Auto-iQ One Touch.
locate sensor inside CF091
i need to open up Ninja and locate the sensor and bypass, even on a full carafe after 3 seconds it beeps and stops brewing
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Probably not the sensor. It is probably clogged in the upper part before the spout. I have had 3 of these machines that all did that right after about a year…I finally figured out the problem.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Hi Brent! Were you able to unclog your machine? If so, would you be able to share how? Thank you!
из
Yes, please elaborate on how to fix this. Maybe cleaning with a pipe cleaner? Nothing seems clogged, though. The water comes out just fine. It just stops after a few seconds and beeps.
из
Добавьте свой ответ
Sharon Dusenbery буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 19
За все время: 1,144
