Инструкции по ремонту и информация о разборке MacBook Pro 16", выпущенного в ноябре 2019 года. Модель A2141, EMC 3347.
My MacBook Pro completely died
My 2019 16" Macbook will not start up...
I bought the Macbook Pro June 2020.
Why would a new Macbook Pro not start?
Apple help can't figure it out either.
Can someone help me figure this out!
Это хороший вопрос?
Счет 3
2 Комментариев
Can you provide any information on when the last time was that the macbook was working? Also, is it completely dead (i.e. no lights no fan no sound)? And is there any light appearing on the AC charger?
из Поделиться
Did you find any solution? Mine died the same way. Just decided not to turn on one morning and none of the usual solutions work. Just over one year after purchase. :-(
из Поделиться
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Just called apple and they gave me keys to test out.
Try this.
Using left hand hold Control & Option
Using right hand hold Shift in unison.
Hold for 7 seconds
While continuing to hold those down
Hold the power button down for another 7 seconds
And release after.
You should see start up screen after a few seconds.
Hope this helps someone!
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Appreciate the post. Power button alone was not working. Using your tip, was able to get control back. Ended up reinstalling the system.
из Поделиться
I would return it to Apple, then maybe you could downgrade to the MacBook Pro early 2008. Those are much better computers, and can run the latest Mac OS with a patcher.
Hope that helps,
Счет 0
Добавьте свой ответ
Arpitha Sylvester буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 29
За все время: 1,285
