Информация по ремонту и разборке беспроводных полноразмерных наушников с шумоподавлением Sony WH-1000XM2.
Left speaker not working
Hi,
My left speaker stopped working. Touch is still working on the left side, right speaker works fine.
Can anyone advise which cables I should check/replace and Mark them in the attached image?
I have opened up the headphones.
Это хороший вопрос?
Счет 0
3 Комментариев
Does the left speaker not work on wired mode(3.5mm cable), wireless mode(Bluetooth), or both?
из Поделиться
It doesn't work wired and unwired
из Поделиться
Hello,
Had the same issue with left speaker no longer working (after crackling for a few weeks),
The continuity of the wires was OK, however there is no continuity in the speaker itself once disconnected from the electronic board.
Do you know where to find a replacement speaker for hw-1000m2 ?
из Поделиться
Добавить комментарий
2 Ответов
Наиболее полезный ответ
This sounds like a connection problem or a bad speaker. Can you take the circuit board and any protecting plastic off the left speaker cup?
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
I should be able to do that. What should I look out for?
из Поделиться
@mrvolcan Make sure there are 2 wires connected from the speaker to the board. Make sure both of the wires have continuity from one side to the other. If both of those pass, comment both checks passed.
из Поделиться
I have the exact same problem. This evening the left speaker if my sony wh-1000xm2 decided to stop working. I don't know what to do.
из Поделиться
I assume it is an connection problem between the pcbs on both sides. I have the same problem now with my headphones. I seems like there is no signal for the left driver. Anybody figured out the problem?
Счет 0
Добавьте свой ответ
Moritz буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 16
За последние 30 дней: 51
За все время: 2,072
