Третье поколение серии фитнес-трекеров Fitbit Charge.
My fitbit charge 3 is different?
As you can see in the image my fitbit charge 3 has three ribbon cables coming from the screen where the one of the teardown has only 2. My replacement screen also only has two. Can anyone explain this? What kind of connector is this?
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Are you sure this is an authentic fitbit? it could be a knockoff that for what ever reason needed another cable
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
I am 99% sure. I also just found the box and it states that this is a special edition with fitbit pay. Maybe that the pay mechanism needed the extra cable, and it makes sence that this is mounted under the glass since the signal doesn't transfer through metal. Also the replacement screen works even without the extra cable!
из
You have a special edition Charge 3. You see them on occasion. If you have the sticker on the back of the screen, that should be removable and then you can apply it to the back of a replacement screen. Otherwise, ignore it and the payment option will just stop working. It's not a big deal if it does so unless you have a use for it.
Счет 0
Добавьте свой ответ
Niels Fennema буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 731
