Руководства по ремонту, разборке и диагностике неисправностей для Apple iPad 5-го поколения с поддержкой 4G LTE, доступного с 32 или 128 ГБ встроенной памяти. Выпущен в марте 2017 года. Идентификатор модели: A1823. Оснащен 9,7-дюймовым дисплеем Retina и 64-битным процессором A9.
Home button not working
Hi,
I purchased an iPad described as “badly cracked screen but everything else working perfectly”
When I received it I discovered the home button wasn’t working. I wasn’t too worried as I noted a hole in screen above home button ribbon cable, and I could just order a screen with a button.
After changing screen I have found it is still not working!
Q1. Could I test it with a home button from an iPad 7? Or would that cause damage/not work anyway? (I ask because I have one that I could try)
Q2. If it's not the home button, how hard/easy would it likely by to have problem diagnosed and fixed? The connector looks fine to my eye.
Any advise on course of action would be appreciated
Thanks
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Выбранное решение
You might have ordered a digitizer with a home button for an iPad Air pre-installed. These are common because the Air does not have touch ID. You have to order a home button specifically for an iPad 5.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Thanks for that, I think you are right.
I ordered an"iPad 5 digitiser with home button flex" but pretty sure button is for Air.
Annoying, but a relief!
из Поделиться
Добавьте свой ответ
Chris Reader буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 22
За все время: 379
