Автомобили Ford Explorer и Mercury Mountaineer были обновлены в 2006 модельном году и получили новую раму, производимую Magna International вместо Tower Automotive.
AC only blowing heat
My blend door actuator started clicking and was stuck on AC. I finally just replaced the actuator and now I have heat but I now only have heat. No matter what I set the temp setting to it just blows hot air out of all the vents on both sides, driver and passenger.
Это хороший вопрос?
Счет 0
1 Комментарий:
i have ford explorer model 2010. same issue of no cold air blowing
checked and found compressor clutch relay not energizing. while jumping he clutch relay contact ,compressor clutch engaging. seems some control logic blocking the signal to compressor clutch relay. anyone can suggest what are the signals blocking the compressor clutch from engaging?
из
Добавить комментарий
1 ответ
I would guess that there is still a problem with the blend door.
If it were “clicking” I would think the actuator was attempting to move the door, but something was wrong with the drive.
Or it could be that the actuator did not get installed properly.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
My only guess is there is something wrong with the new actuator. My setting was already set on cold so it started blowing hot before I messed with it. I’m not sure how it could be installed incorrectly. There is only one plug and the shaft only fits in one way.
из
Did you fixed the issue? Because I’m having the problem too
из
Добавьте свой ответ
Scot Williams буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 25
За всё время: 1,272
