Навыки, которые настолько потрясающие, что не вписываются ни в одну категорию.
Identifying 4mm Posidrive bits
I am looking for #0 & #1 Posidrive 4mm bits (repairing musical instrument). I have the ifixit 54 bit kit but can't identify the Posidrive bits that have been mentioned therein. Anyone know which bits are Posidrive? The only 2 choices in the iFixit 54 bundle are labeled "PH" and "J". Neither of them fit properly.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
HI @oldngray635
The Pozidrive screwdrivers are marked PZ and as far as I’m aware the iFixit kits don’t have Pozidrive heads in them.
PH is for Phillips, and J is short for Japanese Industry Standard, neither of them will be a perfect fit for a Pozi screw as the screw-heads are different.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thank you. See comment to Andrew.
из Поделиться
Наиболее полезный ответ
Posidrive bits are not available in the Mako bit set. You can buy the Manta bit set or get the Pozidrive bits seperately(iFixit 1/4" Screwdriver Bitsand 1). If you buy the bits seperately, you can use them with the Mako driver by using the 1/4” to 4mm adapter at the top right of the Mako Driver set.
iFixit 1/4" screwdriver bits. Replacement bits for the Mahi Driver Kit and Manta Driver Kit. Изображение
Товар
$2.99
Счет 2
1 Комментарий:
Thanks to both of you. I have had this iFixit set for a long time and used it often. BUT, for the first time I can remember I happened to turn it over while putting it away just now and noticed all the contents are listed on the back. My excuse is I am over 90 and this isn’t the only thing I get mixed up. I will check out the 1/4” bit set. Many thanks again.
из Поделиться
Добавьте свой ответ
Don MacDonald буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 28
За все время: 627
