5-е поколение смартфонов линейки Moto E Play, выпущенное в июле 2018 года. Номера моделей: XT1921
Why won't the Microphone work?
My microphone on my Motorola will not work. Whenever I try to call people, they can’t here me.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi,
Try using the phone in loudspeaker mode or insert a set of earphones with a microphone attachment to the headset connector on the phone and check if you can be heard OK when on a call.
If you can be heard then as you say there is a problem with the phone’s internal microphone when using the phone in the normal way on a call.
Use a magnifying glass and a strong light to visually inspect the voice inlet hole, located on the bottom edge of the phone to the right of the charge port, to see if it is blocked with lint etc.
If it appears to be blocked or you’re not sure, do not use a pin or metal probe to try and clear it as you may damage the microphone which is behind the hole. Try using a vacuum cleaner to try and clear it.
If still no good the phone will have to be opened and the microphone checked to find out what’s wrong. Here’s an image taken from the Ifixit Замена экрана Motorola Moto E5 Play guide, showing the location of the microphone.
(click on image to enlarge)
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Doge Productions буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 14
За последние 30 дней: 31
За все время: 799
