Процессор Intel Core Solo 1,5 ГГц, Core Duo 1,66 или 1,83 ГГц, либо Core 2 Duo 1,83 или 2 ГГц. В этом разделе представлены первые модели Mac mini на базе Intel, выпущенные в период с начала 2006 по середину 2007 года.
Mac mini 2007 dead
Hi everyone,
I recently bought a dead Mac Mini from 2007. But when I try to power it on, there is nothing, no light, no chime, not any sound from it. I took apart the logic board and everything seems fine. The charger is working because on the second one i have, it works perfectly.
Do you have any suggestions to measure with multimeter ? Because I’m used to laptops not Mac Mini’s. Thanks :)
Update (03/24/2022)
On the global photo, it’s at the top right
Это хороший вопрос?
Счет 0
5 Комментариев
Can you take a second picture so we can at least read the logic board labels and the cap if its still intact in the location it was located.
из Поделиться
@danj hello, i removed the capacitor the motherboard is a 820-1900-A from 2006.
из Поделиться
It has the same size as the others next to it @danj
из Поделиться
@anthony10006 - Just because it looks the same doesn't mean its the same values.
из Поделиться
Yes i know. Unfortunately, i can’t find any schematic for this board :( @danj
из Поделиться
Добавить комментарий
2 Ответов
Выбранное решение
Le problème venait d’un condensateur en court-circuit. Maintenant le mac remarche mais il me reste à remplacer le défaillant.
The problem was a shorted capacitor. Now the mac works again but I still have to replace the faulty one.
Был ли этот ответ полезен?
Счет 0
Наиболее полезный ответ
Have you tried just replacing the PRAM battery?
You may need to take the logic board fully out so you can inspect the other side. Look for a component that looks discolored or burnt. Often the electrolytic & tantalum caps breakdown. Замена логической платы Mac mini модели A1176
Счет 1
5 Комментариев:
@danj Hi, thanks for your fast answer. Is it possible that the mac could not turns on due to an issue with the pram battery ? Also, as i saw, i didn’t manage to find some dead caps on the logic board, the only thing that i noticed it that a ceramic cap looks weird near the cpu, it is a bit brown not as usual. So i used my multimeter to test for continuity and i have a value of more than 1100 on the line and this seems weird. Thanks
из Поделиться
@anthony10006 - The older systems need the battery to work properly. I would start there.
из Поделиться
@danj hello, i found a dead capacitor and now the Mac works. But i can’t find a schematic for this model. Have you got one please ? It’s 820-1900-A for the board model. Thanks
из Поделиться
@anthony10006 - Sadly I haven't found any for the Mini's. Best to ID the cap's specs how about posting both images of the cap and the location on the logic board. Добавление изображений к существующему вопросу
из Поделиться
@danj ok, i will send the image in the answers
из Поделиться
Добавьте свой ответ
Correia буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 4
За последние 30 дней: 18
За все время: 686
