Apple Watch Series 2, анонсированные 7 сентября 2016 года и выпущенные 16 сентября 2016 года.
Adhesive inside display cut
Hi, unfortunately while changing the battery of my watch, I destroyed the bridge of the adhesive (with copper underneath) between the middle “island” and the right “island”. It should be connected like the left “island”. Hope someone understands and sees what I mean. Please see my photo.
Now, with the new battery, I cannot start the watch. The Apple symbol pops up for a few seconds, but nothing happens. Is this destroyed bridge the reason?
How can I repair the connection or get a spare part?
Thanks so much!
Это хороший вопрос?
Счет 0
1 Комментарий:
Well, the battery was just ordered from ifixit. 😉
из
Добавить комментарий
2 Ответов
The copper adhesive strip is an EMI shield it doesn't effect the running on the watch. But the lifted edge could be pressing on the battery so I would use a jewelers burnisher to carefully press the edge down.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Thanks so much for your quick answer.
What could be the reason that the watch is not starting?
The battery that I exchanged was bloated.
из
@oliver75 - Sadly, you really can only do swap out of the major parts like the display and the SIP if you are sure the battery is good.
из
Счет 0
Добавьте свой ответ
oliver буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За все время: 339
