Nissan Altima — это среднеразмерный автомобиль, производимый компанией Nissan, который по сути является продолжением линейки Nissan Bluebird, запущенной в 1957 году.
Altim 2006 2.5 - Poor Acceleration
My Altima 2006 2.5 runs perfectly on a flat road but is very lazy while going up a hill.
I have changed the pressure pump, changed all the coils but still the same issue.
Any help??
Secondly, its has a hard starting
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
@laminturay have the OBD scanned. It appears that your Altima has difficulty whenever under a load (where it has to work a bit harder) This could be a fuel problem as well as a combustion issue (poor compression etc.) as well as issues with the emission control. There are to many possibilities and we'll need a good starting point.
There are a few things that can be commonly causing this. You would need to check for a clogged air filter, worn spark plugs, dirty mass air flow sensor (MAF), dirty throttle body, clogged fuel filter, bad fuel pump, failed oxygen sensor, and even a clogged catalytic converter. Anything after that would be deeper inside your engine like blown head gasket, bad piston rings, leaking valves etc. As you can see the list can be pretty extensive.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thank you so much. I will start with the OBD first to see what exactly the issues are.
из
Добавьте свой ответ
Bilal Mohamed Lamin Turay буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 16
За всё время: 675
