Руководства по ремонту Magic Trackpad. Выпущен в 2010 году.
The pointer only moves vertically.
To be more precise there's only a narrow vertical band of the trackpad responding. Touching outside of this, central, band has no effect on the pointer.
I tried connecting it to another MacBook but with the same result. I’ve also tried to remove batteries and replace them with new ones and also to completely disconnect it but nothing.
The same thing happened a month ago, that time changing batteries solved the problem.
Do you have any idea?
Thank you!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
The sensor plate has become damaged. Did you drop it or sit something on it that could have damaged it?
Был ли этот ответ полезен?
Счет 0
4 Комментариев:
No, indeed I left it on my desk for one week during the holidays and when I came back it wasn't working.
из Поделиться
@nikdef - Other than trying a fresh set of batteries they just isn't anything that you can fix (the Magic Trackpad2 has a sealed in battery).
из Поделиться
It's just weird that it is sensible only in that narrow band. Thank you anyway.
из Поделиться
@nikdef - Maybe the battery failed and pressed against the panel from the back side damaging it. Time for a new one.
из Поделиться
Добавьте свой ответ
Nicola буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 19
За все время: 382
