Беспроводной контроллер Xbox Elite Series 2 был выпущен 4 ноября 2019 года и совместим с консолями Xbox One, X и S, а также с ПК под управлением Windows 10/11. Модель 1797.
Left stick drift and delayed response time
The left stick is always drifting. Sometimes it's not noticeable in game but in menu it will cycle up consistently. Sometimes a quick flick fixes it. Other issue is you press the stick in and the action is not always crisp, there is a delay
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
connect the controller to a pc or laptop then open this site, https://gamepad-tester.com/. it will show you how bad its moving. if bad it needs the analogue stick replaced.
Был ли этот ответ полезен?
Счет 2
Hey Tyrone! I was able to fix it by opening up my controller and cleaning the sensors on the left stick. This helped me a ton.
When you get to step 11, make sure you move both the green plastic housing for the left stick's sensors. The one on the right controls the X axis and the one on the bottom controls the Y axis. You most likely need to clean out the bottom sensor with some canned air and it should work.
Saved me a few hundred bucks by not buying another controller! Hope this helps out!
Устранение дрейфа аналогового стика контроллера Xbox One Elite Series 2
Счет 1
i replaced the analog stick but the problem persisted. i think it might have something to do with a capacitor
Счет 0
Добавьте свой ответ
Tyrone Palmer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 23
За последние 30 дней: 46
За всё время: 4,473
