Anker Soundcore Flare Mini — это компактная портативная Bluetooth-колонка, предназначенная для использования в поездках, на открытом воздухе или дома.
Powerbutton broken from motherboard
These are the pieces I found inside the speaker but can't figure out how to fix it.
Any suggestion would be a great help.TIA
Это хороший вопрос?
Счет 4
3 Комментариев
I need help also for this exact same problem. I accidentally disrupted the power button somehow and now the only problem I have is I've poked the power button so much with pencils, needles, Bobby pins, and similar small utensils like that ,that at one point allowed me to power it off and on until one day I stopped working. Is this fixable? Please I need someone's help so desperately this is my one and only blue tooth speaker I have . I can't afford a new one I'm unemployed I have been and I just after 6 years of waiting for a disability approval check finally getting approved starting January 2023 . So I still have some time that will be without my music speaker😞.So if someone can please give me any ideas on how to fix this problem I will be eternally grateful to to you🙏
из
Was this ever fixed? I got same issue.
из
I also have same issues
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Dear just take a small on/off button and soldier it with 2 points.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
What do you mean? Can you please explain that to me more in detail? Thank you I will appreciate it it very much friend
из
Добавьте свой ответ
Mahbubur Rahman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 22
За всё время: 1,189
