Logitech UE Boom 2 — это водонепроницаемая портативная Bluetooth-колонка, известная своим всенаправленным звуком в 360 градусов. Boom 2 выпускается во множестве ярких цветов и вариантов оформления.
Why my speaker is not powered?
Hello guys,
First of all I'm not an english native speaker so sorry for the mistakes.
Couples year ago my UE BOOM 2 fell into sea water and it didn't work anymore, when I get home I just put it in rice and and it stayed in for a very long time. 2 days ago I tried to charge it (there is the blinking white light) and to turn it on and it worked for like 30 seconds I was able to put music and then it turned off saying that there was no more battery. Basically every time I plug it and I wait a bit I can turn it on during few seconds. I managed to unplug the battery (Li-ion 3.6V 3200mAh) and tested it with a voltmeter. It says that the battery voltage is 4V, then I concluded that the battery was fine and there was an issue with the powering of the speaker. My questions are : have you ever seen something like this ? Do you have any advices about the pieces I should test or replace ? Does anyone know how to fix it ?
Thank you
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
You should look at the PCB inside of the speaker as well as any connected terminals. Since it fell into Sea water I suspect that there is major corrosion going on despite the rice.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Eliott Guira буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 278
