Руководство по ремонту умных часов Fitbit Versa 2. Выпущены в сентябре 2019 года.
Can the back Panel be replaced?
The back panel on my Fitbit needs to be replaced. The section right by where the pin goes has been broken and no longer hold the pin in on the strap. Can this be replaced and if so what do I need to do? Thank you
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi
You can indeed replace it but it involves a full housing shop
Here’s a video showing how to do it!
https://youtu.be/ZeT1Zmbt9QE
As for the part you can probably find it on eBay or AliExpress
And for tools I recommend iFixit tools as they are top quality and will get your job done very nicely:-)
So maybe pick up one of their tool kits as they will have the bits and pieces you will need! But it’s up to you where you get it from
If you need any advice with doing the repair just ask
Hopefully this helps
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Sylvia King буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 687
