Встраиваемая посудомоечная машина — нержавеющая сталь, ширина 45 см Посудомоечная машина
does not heat water
washes with cold water only.it does not heat water
Это хороший вопрос?
Счет 0
1 Комментарий:
Hi,
Please confirm the model number of the dishwasher.
It seems as though the heater may be the problem and if your dishwasher model is not a Bosch SRI45T45EU-18 anyone answering your question may link the incorrect part suitable for your model.
Moderator
из
Добавить комментарий
2 Ответов
Open it. Look for the heater and measure its resistance. For a 230V Type ist should be near 24 Ohm, for a 120V Type around 10 Ohm. And: there is a pressure switch that ensures that the heater only works when there is enough pressure.
Был ли этот ответ полезен?
Счет 0
Hi - I was able to repair the Bosch dishwasher with this exact problem. It is an issue of the relay as described in this video:
https://www.youtube.com/watch?v=Jb8gAnMb...
You need to get an NTE R46-5D12-6 relay and replace it. Less than $5 part.
Счет 0
Добавьте свой ответ
ahmadmomani буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 16
За всё время: 502
