Руководства по ремонту легкого дрона DJI третьего поколения. DJI Mini 3 Pro был выпущен в мае 2022 года. Номер модели: CP.MA.00000488.01.
GPS module not detected
After a crash, the drone does not detect its gps / IMU module.
There is no apparent damage on the drone, but it can’t detect gps anymore, the gimbal doesn’t move, and the IMU reports an error.
With that, the drone motors won’t start.
Everything else works. Still can take pictures, make films, etc.
Could a gps/IMU module have been broken at impact, but not no physical damage in the outer shell?
Это хороший вопрос?
Счет 0
2 Комментариев:
Hi there. Trying to calibrate compass or IMU simply get stuck and does not work.
I was thinking of opening it to see it it’s a loose cable, but wanted to get a sense if it’s a thing or not…
из
No crash drone tower sight fly good fly next time fly no fly
из
Добавить комментарий
3 Ответов
Yes. It could be as simple as a connector becoming loose or a quick calibration. There was some laptop software that would do a complete calibration. You could get it from DJI website.
I have had to replace broken components but first I would do a gps and IMU calibration.
Был ли этот ответ полезен?
Счет 0
If calibrating the drone does not restore the GPS, try replacing the module. I made a detailed video tutorial here Замена GPS-модуля DJI Mini 3 Pro
Счет 0
Man I have the same issue, but I open the Drone and discovery the flat cable of gps are broken.
Just buy one in alyexpress and be happy.
In YouTube have a video whit disassemble mini 3.
Счет 0
Добавьте свой ответ
feliperosacunha буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 33
За все время: 3,380
