Руководства по ремонту и поддержка картриджей с постоянной памятью, используемых в Game Boy, Game Boy Advance и других портативных консолях Nintendo.
Pokémon Blue Game Problem
I just got an authentic copy of Pokemon Blue from eBay that I'm wanting to fix. The issue is that there is a huge black square where the characters are set to appear. How can I fix this?
Also, this is the first game boy cartridge that I'm actually going to attempt fixing, so I would like some pointers too if that's alright with you guys.
Update (08/07/2022)
I know that the game will definitely need a new battery, but now the game won’t get to the title menu whenever I put a cartridge in.
Update (08/05/2022)
@hellomacos here is my multimeter. What setting do I need to set it on?
Update (08/05/2022)
Here is what the inside looks like
Это хороший вопрос?
Счет 1
10 Комментариев
I’ve resoldered the chip, and now it won’t boot up at all[image|2713211]
из Поделиться
Did you post a pic after soldering. Looks like you tried but can’t see anything.
из Поделиться
I fixed the bridging in the pins, but the game won’t still boot up. At least it can be read
из Поделиться
@texedo
Look at my original answer
I have updated it with something for you to follow along with:-)
из Поделиться
I’ve tried it, and it still doesn’t work
из Поделиться
Показать ещё 5 комментариев
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Hi
I believe this issue is caused by corrosion on the PCB or loose pins
You may need to repair some traces by soldering them back with jumper wires but it will probably just need some isopropyl alcohol and cotton buds to clean it up
As for loose pins you will need some fresh solder and flux for them, it’s not to hard you just need to solder them down carefully
Here’s a video on fixing them up!
https://m.youtube.com/watch?v=xYUW0uVBp0...
Hopefully this helps
If you need any help just ask
Edit: if you clean the spots I have high in red with isopropyl alcohol it may resolves your issue
If not let me know and we can continue diognostics:-)
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
I don't know if this is the same link or not but this guy just fixed the same situation.
https://youtu.be/xYUW0uVBp0k
Sorry, never did one myself either but am looking up for info myself.
из Поделиться
@ace_boy2786
It usually is different across different game cards
Best thing to to is take it apart and see what’s happening :-)
из Поделиться
Look at the chip on the bottom left of your pic. Left side has corrosion on quite a few pins. Clean it off with some ipa and re solder every connection on the board.
Счет 1
2 Комментариев:
I have resoldered the chip, and now it won’t boot up at all
из Поделиться
Can you post a pic of the board after the soldering please pal?
из Поделиться
Hey there! Congrats on getting your hands on an authentic copy of Pokémon Blue. Regarding the black square issue, it could be related to a display problem or a cartridge connection. I suggest checking out some online forums or YouTube tutorials for troubleshooting steps specific to your situation. As for the battery replacement, that's a good call, and it's great that you're taking on the task of fixing your own game. Remember, there's a vast community of gamers out there who are always willing to share their knowledge and help each other out. By the way, speaking of gaming, have you ever tried blackout bingo? It's a fun and exciting game that adds a new twist to the traditional bingo experience. Just make sure to enjoy it responsibly and have a blast! Good luck with your Pokémon Blue fix!
Счет 0
1 Комментарий:
It's a solder issue. Reflow every leg on the chips and it will work again.
из Поделиться
Добавьте свой ответ
Will York буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 20
За последние 30 дней: 57
За все время: 1,855
