Canon EOS 60D — это 18-мегапиксельная цифровая зеркальная фотокамера (DSLR) с поворотным ЖК-экраном. Камера была выпущена в августе 2010 года; модель можно опознать по надписи «EOS 60D» на передней панели.
60D quick control menu not visible
I just bought a Canon 60D and while i was setting it up for use as a webcam i tried to integrate either EOS utility 1 or 2 with OBS it broke my camera. It didnt respond so i turned it off and didnt think much of it.
A while later i turned it on again and whenever i switch to any other mode than movie the screen goes black, i can take pictures and look at them i can also go into the menu but i cant for any reason look at (i think its called) the quick control menu with all the camera settings like shutterspeed.
Anyone know of this problem and how to solve it?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
If you're having trouble seeing the 60D's quick control menu, it may be because you have the camera's LCD brightness turned down too low. To fix this, press the INFO button and then use the Quick Control Dial to adjust the brightness level.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
i can see the menu and photos clearly but not the quick control, this is not a brightness issue but thanks
из
Добавьте свой ответ
Mark William буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 12
За всё время: 452
