Ремонт и информация об устройстве для 50-дюймового LED-телевизора Vizio D-series с номером модели D50n-E1.
Why is my remote not working?
I own a Vizio 50 inch model V 505-G9, purchased at Sam's Club in July 2020. Vizio sent me a new remote but the tv will not respond. The only way I can turn on the tv is manually at the back. Remote not functional.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Edward Reinert since this is a new factory remote we can rule it out (hopefully) and I am sure it is not a user error. New battery and all I assume. The only thing then is the IR sensor on your TV. Make sure it is not obstructed and make sure that the plastic cover in front of it is clean. If all that checks out it is possible that you will need a new IR board. We would need to know your exact model number and you will have to remove the back cover tec. for that. Of course, check to see if it is still under warranty etc. If so let them fix it to their cost, not yours.
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
Edward Reinert буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 19
За все время: 324
