Кофеварка De'Longhi BCO430 — это комбинированная кофемашина для приготовления эспрессо и капельного кофе на 10 чашек, оснащенная капучинатором, выполненная в серебристом и черном цветах.
There fog in my timer
Hello I made a cappuccino and I think some water spilled to the clock and is now foggy how do I fix it ?
Update (10/08/2022)
Can you see the images? not sure if it got uploaded properly
Update (10/08/2022)
Did these images come ok?
Это хороший вопрос?
Счет 1
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Hi
Unfortunately there aren’t many options
You could leave it in a very dry environment until the moisture drys up
Or you could take it apart and see what the issue is from the inside(eg broken seal)
Unfortunately there aren’t many guides on taking it apart so if you decide to take it apart I can try and help guide you if you would like
Hopefully this helps
Any questions please ask
Был ли этот ответ полезен?
Счет 1
8 Комментариев:
Can you help me with replacing the boiler lid on this one? I am not able to figure out how to expose the boiler fully so that I can replace it. I am able to access it from the top, but that will not help me remove the boiler. Thanks in advance.
из
@valchrisfamily
If you can upload some photos of what stage of dissasembly you are at using this amazing guide I can try and guide you
Добавление изображений к существующему вопросу
из
Uploaded 4 pics. The last one shows a close up
Of the boiler where the water input nut is broken and needs to be replaced.
из
Also - I did open the bottom as on the video. It the video was solving a problem with the drip coffee maker. I could not find a way to open the espresso side of things.
Thanks for any tips.
из
@Valentine Christopher
Thanks for the images(they all came through just fine)
Let’s start by removing the 4 screws on the right side of top of the machine to see if that uncovers anything
(Just to let you know I haven’t actually worked on this specific device ,iv only ever worked on things similar to it, so I’m just using my repair knowledge and priory experience for these sorts of devices)
из
Показать ещё 3 комментариев
These coffee makers often are similar. Compare to Снятие бойлера Saeco Magic Capuccino SIN017 and Starbucks barista , perhaps it helps. Good luck!
Starbucks Barista Изображение
Инструкция
Разборка кофемашины Starbucks Barista
Сложность:
Умеренно
Saeco Magic Capuccino SIN017 Снятие бойлера Изображение
Инструкция
Сложность:
Умеренно
Счет 1
Pics attached - this is how far I could get
Update (10/08/2022)
Счет 0
Update (10/08/2022)
Счет 0
Добавьте свой ответ
liluet_hernandez буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 33
За все время: 510
