Sony Vaio Battery Screws
Lost the two screws holding my battery in. Your site says they are 11mm. I assume that is the length. What is the diameter and pitch?
Это хороший вопрос?
Это хороший вопрос?
Hi
Sorry but I don’t have a laptop to check but I have a solution!
From what the other guides show ,they all look to be roughly the same so I would measure the other screws on the bottom and check to make sure they fit the battery’s slot holes and order them accordingly
Hopefully this helps
Any questions please ask
Был ли этот ответ полезен?
I tried that before asking for help. The other screws are all too small or too short. I took the laptop to the hardware store and found the closest metric fit to be 2mm by 0.4 pitch by 12mm. But even it was a little wobbly. But they are holding. I placed electrical tape over them as they stick up a bit and will scratch.
Have you considered buying a box full of screws and sewing which ones work best?
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 33
За всё время: 367
