Apple's seventh-generation smartwatch, with optional cellular connectivity, released October 15, 2021.
Apple Watch Body Repair
Is the Nike Apple Watch Series 7 body and glass repairable?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
The Nike Watch models are the same as the Apple Watch models for a parts other than the SIP unit which is programed with a slightly different ID string.
As for getting parts to do it your self or independent shop, so far the part supply is quite limited. I haven't found a source fo the display assembly which is a common repair.
If the case is also damaged then I would just go to an Apple Store to get your watch serviced.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Jeff Bennett буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 470
