Right clicker does not work occasionally.
Это хороший вопрос?
Это хороший вопрос?
Check Hardware Issue. If you encounter the issue mouse right-click not working, you can plug your mouse into a different USB port first and check whether the issue of right click not working is solved. Then if the above way does not work, you can also change another mouse and plug it into your computer.
Regards,
Will
Был ли этот ответ полезен?
I fixed it, just needed a clean and some tape.
Worst case scenario to consider,
You've clicked in excess of 100 million times and the switch has fatigue failed. This is expected after 3-4 years of daily use. I bought a bag of omron 50M rated switches for all of my mice.
@normalladd Thanks, for the tip!
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 52
За все время: 1,956
