Ноутбуки HP Envy 15t отличаются наличием строчных букв «hp» в центре нижней рамки дисплея.
Blue screen of death
Hello I was using my laptop with no problem since I got it so I tried updating windows and it was stuck on %100 so I restarted my laptop thinking everything would normal ones it's on but I got the blue screen instead with critical process died stop code , I have tried everything but nothing works resetting,startup repair, uninstall updates nothing works but when I try system restore I have to tick a little box on the disk I'm using but I don't have a mouse pointer to tick the box, please help me.
Это хороший вопрос?
Счет 0
2 Комментариев
@vybzonline update which part of Windows? Update to what?
из Поделиться
@oldturkey03 I was updating the windows 10 because it was not up to date.
из Поделиться
Добавить комментарий
2 Ответов
Наиболее полезный ответ
How to fix a Blue Screen of Death on a Windows PC
Uninstall incompatible software.
Run a memory checker.
Check for hard drive errors.
Remove non-essential peripherals.
Replace defective or incompatible expansion cards.
Run Setup Diag after a failed Windows update.
Perform a clean install.
Regards,
Will
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thank you for your reply
из Поделиться
Hello I will suggest you the following.
  1. Use specialized BSOD repair software.
  2. Uninstall critical third-party programs.
  3. Run SFC.
  4. Check all drivers if any driver is outdated update driver.
  5. Backup your data and clean install Windows
Счет 0
Добавьте свой ответ
Abdul Malik Suraj буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 17
За все время: 395
