Второе поколение магнитных адаптеров питания переменного тока для устройств MacBook, впервые выпущенное в 2012 году. Не совместимо с системами предыдущего поколения. Доступно в версиях на 45 Вт, 60 Вт и 85 Вт.
Check if work with multimeter
Hi everyone,
I have x3 MagSafe 2 - 85W adaptors which I want to sell but I want to be sure they are fully working. I sold my old MacBook and non of my friends have MagSafe compatible Mac so can't check it direct way. I have multimeter at home.
How can I check this charger with multimeter to know if its work or not?
Would appreciate your help
Update (12/09/2022)
@geirandersen I set a multimeter at the setting (see pic) and the it showed 3.1
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
@roderos I’ve attached a pinout image for the MagSafe 2 charger.
Test black probe on Ground and red probe on Power. Both Power pins should have very similar output. If there’s a large difference or the voltage if the voltage isn’t ~20V, you have a bad charger. By large difference I mean anything more than a few millivolts.
Был ли этот ответ полезен?
Счет 6
16 Комментариев:
So the output from both Power pins must be around 20V?
I have 85W charger.
из Поделиться
@roderos Yes. You can use any of the Ground pins, but both Power pins should have ~20V. Output voltage doesn’t change with Wattage rating. It’s the amperage that it can possibly draw that is higher on the higher rated chargers.
из Поделиться
@geirandersen just have a chance to test it out now. sorry for silly question, do I need to have charger plugged into the wall to test it?
из Поделиться
@roderos Yes, the charger must be plugged in to the power, otherwise it has no output ;)
из Поделиться
@geirandersen thanks :) I tested x3 chargers both pins an all of them show 3.08-3.1 at DC Voltage 20. Does that mean that they work at full power?
из Поделиться
Показать ещё 11 комментариев
Добавьте свой ответ
Yurii Chaikovskyi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 25
За последние 30 дней: 147
За все время: 13,511
