Meeting Owl Pro — это система, включающая в себя камеру с обзором 360 градусов, микрофон и динамик, предназначенная для совместных конференц-звонков.
How to replace camera
I have an Owl Meeting Pro that fell off the table and now the camera is broken. The top dome appears undamaged but something in it is broken. The camera picture is mostly blurred/black. Its this something that can be repaired?
Это хороший вопрос?
Счет 10
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi Caroline. I know its been a while and my answer will probably not be helpful to you at this point. When the Owl webcam falls off (because most of its weight is in the top, so it is easy to tumble), it often breaks inside the lens. The fisheye lens is built like a cone or a mushroom and it will break where the lens comes inside the cone to each the camera sensor.
That being said, there is no replacement lens available (well, at least not documented). The only workaround is to find a donor webcam from which you will get the lens (and the camera sensor if needed) and "transplant" it to the webcam you are trying to salvage.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
caroline work буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 15
За последние 30 дней: 60
За все время: 1,892
