I can't open monitor back cover
Could you help with instruction how to open monitor back cover - I can't understand how to do it? I already have been removed 4 screws, but how to find clips and what to do next I can't understand.
Это хороший вопрос?
Это хороший вопрос?
the back usually doesn't come off on monitors.
the typical teardown is done by removing the screws (which you've done) and then carefully prying the bezel cover away from the display from the front of the monitor.
Был ли этот ответ полезен?
I have a feeling that I need to do something with clips, etc. Because I can't remove easily cover :(
hm. when I took my monitor apart I had to use some force to get the clips off because they are held on fairly tight
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 38
За всё время: 1,260
