Руководства по ремонту, разборке и поиску неисправностей для Apple iPad 8-го поколения с поддержкой Wi-Fi, доступного с накопителем объемом 32 или 128 ГБ. Выпущен в сентябре 2020 года. Идентификационный номер модели: A2270.
Replacement screen is a bit blurry
I replaced the screen on my iPad and the screen dose not look even close to as good to the oem one in the pic it is hard to tell but the white one with a replacement screen is worse.it is almost like there is another layer of protective plastic that needs to be removed even know I took off all the plastic that had tabs of was obvious, even after taking all the plastic off it has manny scratches. I’m looking to know if there is another layer of plastic or any good brands to get another screen from.here’s the link to the screen that I got MMOBIEL Digitizer Front Glass... https://www.amazon.ca/dp/B08H8PQX6B?ref=...
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
hello Josh,
unfortunately, I have bad news for you. The digitizer is of low quality and astronomically expensive. I even think you overpaid at least 2x. The nice curve of the digitizer tape defends itself (glueing), sloppy tapes usually rise and cause the surface of the screen to rise. However, I expect poor quality glue on the edges, and the scratches are terrible. Worldwide, this digitizer costs about $12 and in the version without glue, folded tapes and front camera bracket even $8
such a digitizer like this one should have two pieces of protective plastic: one on the outside and one on the inside. The inner one acts as an antistatic dust barrier, the upper one should protect the antiphobic coating, which is probably not here, but that's another thing.
Are you sure you removed both layers of plastic? If you also replaced the matrix, there will also be a protective plastic on this one. More details can be found here - step 20-21
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Josh буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 485
