Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
Flashing question mark folder on boot up
I was gifted a Mac Mini model A1347, I believe its a late 2014 model. 2.6GHz Intel Core i5 with 8gb of LPDDR3. I was told the Mac has only been used a handful of times since its been purchased. When I tried to boot, I got a flashing ? folder, and after research I've found that this is most likely because the mac no longer has a working operating system. I'm not familiar with Apple products at all, so I'm wondering what my next course of action should be. Attempt to boot from a USB with a current OS? Would Geek Squad possibly still work on it even though its outdated? Thanks!
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
If you have another Mac: https://macdaddy.io/install-disk-creator...
Download Your Desired MacOS (I recommend 10.14 Mojave) and Follow they're guide...
Otherwise Hold Down: https://support.apple.com/en-us/HT204904
When In MacOS recovery, Go to Disk Utility, Check for a Partition that could have MacOS.
If there isn't one, Try Partitioning it to MacOS Extended (Journaled). Then try to install MacOS.
IF THAT DOESN'T WORK, It's likely A failed Hard Drive/SSD.
Part: OWC Aura Pro X2 SSD or [связанный продукт отсутствует или отключен: IF107-098] or [связанный продукт отсутствует или отключен: IF107-142]
Guide: Mac mini Late 2014 Hard Drive Replacement or Mac mini Late 2014 SSD Replacement
Replace or upgrade the PCIe solid-state drive in a variety of Macs. Изображение
Товар
OWC Aura Pro X2 SSD
$239.99
Mac mini Late 2014 SSD Изображение
Инструкция
Сложность:
Умеренно
15 minutes
Mac mini Late 2014 Hard Drive Изображение
Инструкция
Сложность:
Умеренно
30 minutes - 2 hours
Был ли этот ответ полезен?
Счет 2
Lucky for you there's an entire page on this exact issue. It's for MacBook, but the concept is largely the same.
As a former Geek I can say with confidence, Geek Squad would also still work on this if you decide to go down this route. Although it's usually a pretty straight forward. Bear in mind your options may be somewhat limited depending on what they find. If it's a hardware issue, that isn't something they can take care of in store.
Счет 1
1 Комментарий:
@flannelist - You Beat me to it! :-)
из
Добавьте свой ответ
Christian Berent буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 13
За всё время: 482
