Беспроводная гарнитура, не поддерживающая Bluetooth, с возможностью проводного аналогового подключения. Это версия 2019 года SteelSeries Arctis 7 Wireless (не-pro версия), которую можно определить по номеру модели HS-00013 на наклейке под амбушюром.
Is the main internal audio cable replaceable?
I'd been struggling with a wobbly right headphone for a while, and it recently fell right off the headband. after putting it back on, I noticed that it had totally lost sound.
After disassembling it, I found a few split lines on the cable connecting left to right, probably from the busted mount for that whole headphone ripping it up.
Would there be an easy way to replace that whole cable or would I need to assemble one on my own?
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
I had the same problem. Mine had broken right at the plug so my only option was to cut away the female part of the plug off the PCB board and solder the 11 cables directly to the PCB board. Sounds hard and looks harder but I'm a complete beginner and this was my 1st ever-soldering adventure and didn't struggle much! The only thing is that there are 2 whites and 2 browns so I opened the cup that wasn't broken and used an electrical tester to make sure they were in the correct order
Ps they don't touch it just looks closer in the picture and I painted over the cables with liquid electrical tape to stop them from ever touching.
and I looked everywhere before doing this and the only way I could see getting replacement cable was to buy broken pair, but as its a common fault it's likely to be broken on those too :D
Был ли этот ответ полезен?
Счет 0
does this fit
https://www.aliexpress.com/item/10050022...
Счет 0
Jag har samma problem. hälften av
Mina har gått sönder precis vid kontakten, har nyss trasslat ut allt och fästa kabeln o kontakten på på en trä bit.
tror jag ska försöka löda ihop dom 5 som e av och behålla kontakten hel.
vi får se hur det går ( hint ) jag e inte van att löda ;---) dom e små dom rackarna.
Счет 0
Добавьте свой ответ
seadub5 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 8
За последние 7 дней: 17
За последние 30 дней: 38
За все время: 1,295
