Представленный 3-его марта 20 17 г. Nintendo Switch- это портативная приставка, способная устанавливаться в док-станцию и выводить картинку на TV
SD Card Holder Broken
I recently got my screen repaired and ever since then my SD card wont rea although its in. I recently bought a new SD card and formatted it and inserted into console, it wouldn't read so I tried 3 more times and still wouldn't work.
How do I fix this?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @gwirl
How long ago since the screen was repaired?
If only recently take it back to the repairer and show them the problem.
Any reputable repairer will give a guarantee on their work even if only for 30 days and that means that the device should have been fully tested and working before it was handed back to you.
You can always check that the SD card reader is connected properly to the motherboard. Here's the ifixit Nintendo Switch Motherboard Replacement guide. The SD Card reader can be seen being removed at Steps. 9-10
Был ли этот ответ полезен?
Счет 1
Hi Nate,
Actually, I'm going to point you to a different guide, the SD Card Reader guide; it only deals with the reader.
Nintendo Switch Micro SD Card Reader Replacement - iFixit Repair Guide
There's a note at the final step about reassembly that you'll be particularly interested in.
During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
When I was writing the midframe replacement guide, the only issue I ran into was with the SD card reader; I hadn't gotten it plugged in all the way and had to open it up again and redo it. Removing the foam pad was the key for me; I could then feel when the connector snapped in place and once I reglued the pad and closed it all up again, it was all good.
So yeah, take @jayeff's advice and open it up and check that connector; with any luck that's all it is and you'll be up and running again soon.
Good luck; let us know what you find.
Счет 1
Добавьте свой ответ
Nate Johnston буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 14
За всё время: 181
