Ксеноновый фонарь Mini Maglite AA от компании Maglite
How do I remove corroded batteries?
The batteries are very corroded. So much that I have not been able to unscrew the end piece at the led end of the body.
Это хороший вопрос?
Счет 1
1 Комментарий
Same problem here. Can’t get the end off even with a wrench.
из
Добавить комментарий
2 Ответов
Выбранное решение
This answer should solve your problem:
used Ikea AA, after a year, how can get the battery out?
Был ли этот ответ полезен?
Счет 2
If they are very dirty as you say, I’d suggest using some using some sort of stick of some sort to peel out the AA batteries depending on which type of battery if they are normal batteries, I suggest you use rubber gloves do not touch the battery corrosion because it can make very bad irritation happen to the body and I suggest after you remove the batteries try and use IPA alcohol I am on the contact pads with an earbud cleaner
Счет 0
Добавьте свой ответ
Jim Tenorio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 33
За всё время: 2,760
