How to fix charging port
Charging port needs repair
Это хороший вопрос?
they are usually replaced using hot air, a soldering iron, solder and flux
Был ли этот ответ полезен?
Thanks for your answer but I really need step by step instructions on how to carry out the replacement. What tools I will need and stuff like that as well.
@johncam you would need a soldering iron with a small tip, a hot air station, flux and solder. https://www.youtube.com/watch?v=RlwB1Itz...
If you don't have any experience (micro)soldering your best bet would be to find a replacement part if it isnt soldered on to the motherboard, if it is, you probably want to take it to a repair shop... Soldering a USB port with no experience is no easy job
За последние 24 часов: 0
За последние 7 дней: 12
За последние 30 дней: 32
За все время: 624
