Четвертое поколение Nissan Altima (модель шасси L32A) было представлено на Нью-Йоркском автосалоне 12 апреля 2006 года. Это был первый автомобиль, использующий уменьшенную платформу Nissan D с новой передней и модернизированной задней подвеской.
07 Nissan Altima Acceleration issue
My Altima has 118k miles, was jerking and hesitant when going into drive and reverse, so I parked it. It had a lean code p171 and p300 misfire code so i changed spark plugs and coils, valve cover and gasket, MAF, cleaned throttle body and checked all the fuses. It still does not accelerate, but the RPMs will go high (past 4k) until i let off gas pedal. Goes into all gears just fine, reverse has no issues now, but when i put in drive it feels like its in limp mode. Checked the alternator and its fine, also car has a new battery too. Im at a loss. I still owe $4k on this car and was quoted $2k for a used installed tranny. I really need help!!! Oh i had a TPS code and a throttle actuator code come up 2101, 123 & 223 then realized I had a loose sensor on the throttle body. I cleared the codes and check engine light went off but still doing it. Please Help!!!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Are you sure its not in limp mode? Also it sound like the auto transmission may be slipping.!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Robin Shepherd буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 326
