20-, 23- и 30-дюймовые ЖК-мониторы в алюминиевом корпусе, представленные Apple в июне 2004 года. Модели A1081, A1082 и A1083 соответственно.
Adding a Fuse to Protect Display
The Apple power supply finally bit the dust, it was used on my 30" Cinema Display. I have purchased one of the $20 240 Watt, 10 Amp power supplies to replace it. I would feel much more comfortable using this inexpensive PSU if I could add protection between the display and the power supply. I welcome any advice on how to add a fuse with the goal of not destroying the display should the power supply go haywire.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
@charles218 lets see what the end connectors look like. You can always add a 25 V 8 A inline fast-blow fuse.
Был ли этот ответ полезен?
Счет 0
6 Комментариев:
I am planning on removing the connector from the dead Apple power supply and using it with the new power supply, this way I don't have to cut the display cable. It looks like the fuse would need to go between the recycled connector and the power supply tap.
из Поделиться
@charles218 yup. Right one the power lead.
из Поделиться
Is it important that the fuse holders wire be the same gauge or close to the same gauge as the connection wire?
из Поделиться
@charles218 not on that length. You'll be fine with slightly smaller/bigger leads.
из Поделиться
Old Turkey, you have been very helpful, thanks! I searched for the past half hour or so for 25 V - 8 Amps without success, nothing comes close, so if you or anyone has any leads on where I can find it, please let me know.
из Поделиться
Показать ещё 1 комментарий
Добавьте свой ответ
Charles Larkins буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 17
За все время: 510
