Ноутбук HP Envy x360 m6-aq103dx оснащен сенсорным экраном и может раскрываться на 360°, что делает его устройством «2-в-1» для тех, кому нужен ноутбук и планшет в одном корпусе. Номер модели: W2K45UA.
Error Code on Caps Lock
Every now and then I would get this error code and it would go away and now it's constantly doing it.
Caps Lock Error:
3 Long
2 Short
I took the screen off to see any loose cables and there were none, also took the bottom cover to check and same result. I thought about changing the CMOS batter this board has but idk how to take that out. Any recommendations would be great.
Это хороший вопрос?
Счет 0
1 Комментарий
The issue was one of my RAM sticks went bad. Thank you @flannelistt (Alisha C)
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
If I remember correctly, 3 long, 2 short is most likely a RAM issue for most HP models. In fact, blink codes in general are most often cleared on laptops by a simple reseat of your RAM.
That seems to coincide with your “every now and then” sort of experience. Maybe one of the sticks is just loose.
If you confirm the exact model number of the machine, we can probably confirm this and get some service documentation. But I would pop off the bottom off the laptop, unplug the battery (the regular one, not the CMOS one), then pull your RAM stick(s) out, then put them back in and see if you’re in business.
Был ли этот ответ полезен?
Счет 2
5 Комментариев:
HP Envy x360 m6-aq103dx as it says on the back.
из Поделиться
@xfuskyx Just making sure, with Windows machines, there are so many I always want to be certain. The Service Manual will give you the rundown on how to get the unit open, how to disconnect the battery, the RAM, even the CMOS battery if you wanted to give that a try.
из Поделиться
Thank you, I'll give this a try and update you.
из Поделиться
Ended up being one of the RAM sticks. Thank you.
из Поделиться
@xfuskyx My pleasure. Glad it was an easy fix!
из Поделиться
Добавьте свой ответ
Bryan Fuscarino буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 22
За последние 30 дней: 50
За все время: 1,411
