Front cam black screen / disabled flash / cooldown error
hello friends,
I am having a problem with an ipad 9lte.
the charge port got broken. I replaced it but then when I tested it, the front cam was not working. it gives an error with flashlight and full black screen. The back cam is fine.
I tried different front cams and back cams. nothing changed.
I am adding 2 photos. one is marked with pins on the front cam connector. 5-6-7-8 are giving OL , I am just curious if you have a board can you measure for me? Also the other picture that I need is a place where I think is a problem. I need a picture of that area for conparison.
edit: sorry I forgot to ask the question :) what is causing this issue? Has anyone exprienced this?
Thank you so much.
Это хороший вопрос?
Счет 0
2 Комментариев:
did you solve the problem with Air4 we talked about a while ago?
из
I am still waiting for the chip. It is delayed. I am gonna update if I solve it.
из
Добавить комментарий
