error codes F1E9 or E9F1
Kitchenaid dishwasher #KDPM804KPS
Start Dishwasher on normal cycle time is 2:53 minutes count down, it get to 46 minutes
And stop counting down this last for 12 minutes and then start flashing F9E1 error code,
when I open it up the hot steam comes out but water is standing on the bottom
as high as the bottom of heating element .
Now if I let it cool down and press cancel and drain it drain just fine
or if I only use the rinse only cycle it works fine, I have replace the control board
and the same thing happens?
It is only two years old.
Thank you
Это хороший вопрос?
Did you ever figure out the issue? Having same problem…
из Derick Brady
