Информация по ремонту и техническая поддержка несамоходных газонокосилок производства компании Toro.
Front wheels not straight
On the toro 30” time master are the wheels supposed to look as they are leaning outwards and not straight? We haven’t even used ours yet , unloaded it yesterday and just want to make sure the front wheels are right before using it. Thanks
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Since it is new, it is possible that the bolts holding the wheels in are loose. In the center of the wheels, there should be a screw or bolt that needs to be tightened. If there is no bolt visible, look closer, as there may be a cover to keep grass out.
It is worth noting that I don’t have this exact model lawnmower, but most are pretty similar in design, so please take this with a grain of salt.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Will definitely check that, thanks
из
Добавьте свой ответ
Amanda Chandler буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 25
За все время: 463
