How do I replace the charging port?
Charging port damaged and will not charge with a cord attached. The cord slides out.
Это хороший вопрос?
Счет 5
2 Комментариев
Hi @stephaniel52636,
What is the model number of the phone as there is a Moto G Stylus 2021 model and a 2022 model?
из
هذه المشكله من أهم المشاكل لواجهها
Translation Arabic - English
This problem is one of the most important problems to face.
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
@stephaniel52636 luckily the charging port is soldered to a daughter board. All you have to do is to replace this board. You are looking at something like this As for getting to the board use something like this video
Был ли этот ответ полезен?
Счет 1
First: use a toothpick to check if there is debris. I can't be build up, so pry a little bit. If that doesn't work, you can change the chargeport. Changing the chargeport requires knowledge of fixing phones. Seek a local phone repair shop.
Счет 0
Well this video might be helpful for you :https://www.youtube.com/watch?v=CGX0s44d...
Счет 0
Use wireless charger
Счет 0
1 Комментарий:
Hi @hollyhoffm84436
Might depend on which model version it is, as the OP didn't specify.
The Moto Stylus 5G (released in 2021) doesn't have wireless charging capability.
The Moto Stylus 5G (2025) model does.
из
Добавьте свой ответ
stephanie l буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 53
За всё время: 2,675
