Информация о ремонте и разборке беспроводной игровой гарнитуры Logitech G533. Гарнитуру G533 можно идентифицировать по номеру модели A-00072. Она была выпущена в январе 2017 года.
Mic randomly stopped working
I can hear the beep which indicates my mic is being turned on when the mic is flipped up to mute and down to unmute. Although i hear the headset is registering the mic being used for some reason, it just stopped working.
does anyone have experience replacing the mic on one of these? if so please share your experience and point me in the right direction for replacement parts.
thank you in advance.
Это хороший вопрос?
Счет 3
1 Комментарий
I had the same issue with 2 Headsets I bought used. One had this from the moment I bought it, the 2nd worked fine for about 1 year.
I guess the problem is a cable failure in the lever mechanism
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi HawgDawg,
I was going to answer, but ran across someone else with a similar problem and the first comment on that question was pretty much exactly what I was going to say, so I'll just link to that question and let you read it for yourself.
Mic doesn’t work - Logitech G533 - iFixit
See the comment by F Dryer (@notbroken ) for a very good explanation of exactly what I was thinking.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Thanks for the reply Jerry
I can't seem to find the comment you're referring to, the thread you linked was helpful though.
из
Добавьте свой ответ
HawgDawg буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 53
За все время: 3,649
