Информация по ремонту и руководства для Apple iPhone 5c, представленного 10 сентября 2013 года. Модель: A1532, A1456
thermal paste under battery?
well, i used a heat gun on this phone to remove the battery... and i notice something sliver under the battery... and the adhesive tab didn't budge (and ended up ripping)
yeah it was kinda hard to see, but still is this normal...?
is this just the base but damaged?
edit its not... it crumbles when you get something under it.. could it maybe be thermal paste....?
Это хороший вопрос?
Счет 1
26 Комментариев
There shouldn't be any thermal paste under there. it would be useless. Any chance you poked through the battery/tore it?
из
@oldturkey03 more than likely the inside of the battery
из
@tech_ni that is what I was thinking. The crumbling would make me think it is :-)
из
@oldturkey03 did know people still bought 5c, i binned about 8 housings with parts
из
@oldturkey03 won 2 items on ebay today for repair, iphone 8 no power for £8.50 and a gopro hero 8 for £17.50 with no power
из
Показать ещё 21 комментариев
Добавить комментарий
1 ответ
Выбранное решение
Could be the old adhesive. Seems to be in the right place. If the tabs break off I either use a heat mat and a spudger to gently lift the battery or put some alcohol down the side of the battery and tilt the phone so it runs over the adhesive.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
timtom77 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 21
За все время: 492
