Ноутбук Ideapad 5-15ITL05 — модель типа 82FG. Этот ноутбук, выпущенный в октябре 2021 года, оснащен сенсорным экраном и может использоваться в качестве планшета.
No Backlight after Water Damage
Working on this laptop for a friend. Has some minor water damage mostly from the right side (nearest display cable connector on mboard).
Assumed the fuse FG3301 for the backlight was blown but it's OK. what else should I check?
Update (05/07/23)
I may get back to this repair later; friend is currently using the laptop with an external hdmi display since the backlight is the only known issue after water damage.
Additional info: the UL indicator label on the board reads
"HSB J
MV-4 E89382
94v-0"
Это хороший вопрос?
Счет 0
12 Комментариев
@isaiahneumann what model is the motherboard? have you checked the display connector? What voltage do you get on there? It could be any component with the backlight circuit. You'd have to trace it to see where the power starts/stops. You did not tell us if the fuse was good or not.
из
Board is "MV-4 94V-0".
Fuse was good.
Not sure which pins to check on display connector. Image and touchscreen work fine.
из
@isaiahneumann do you get voltage at the fuse on both sides, if you do add photos of the lcd connector and the back of the board and also the connector on the screen itself
из
@tech_ni
I only checked the fuse with the mboard entirely removed and disconnected.
из
@isaiahneumann double check on that number. I would have expected a LCFC board for the IdeaPAd 5. something like a NM-D031 Even better. Post some good pictures of your board with your QUESTION. That way we can see what you see. Добавление изображений к существующему вопросу
из
Показать ещё 7 комментариев
Добавить комментарий
1 ответ
Выбранное решение
@isaiahneumann you have a corroded JEDP connector. You want to remove that cable and clean the connector with some high grade isopropyl alcohol. The first 4 contacts (top of your connector picture0 are for the backlight. They look pretty gnarly. You may need a new connector. Remove the cable, clean the connector and post some "after" images. Do not try to power on your board etc. since you may just cause more damage.
Post some good pictures of your board with your QUESTION. That way we can see what you see. Добавление изображений к существующему вопросу You can only add images to your Question which you must edit or to Answers. You can not add those as comments. Those do get lost....
At this point I would probably advise you to clean the complete board with some isopropyl alcohol. Nothing less than 90%. Preferably higher percentage. For as long as your board is not cleaned and you still have corrosion on connectors etc. no proper diagnostics can be accomplished.
Update (05/08/23)
@isaiahneumann here is the pinout for the connector
Since I am pretty confident that this is a NM-D211 board, here is the schematic for it Lenovo Air 15ITL 202 LCFC NM D211 PDF Hopefully your board survived since your cable seems to have taken the damage.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
@isaiahneumann your cable is toast :-) Contact 1-4 is for the backlight.
из
Добавьте свой ответ
Isaiah Neumann буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 42
За всё время: 2,069
