Бюджетный смартфон, дополняющий Galaxy SIII. Также известен как Samsung I8190 Galaxy S3 mini, Samsung Galaxy S III и другие. Доступен в версии Samsung I8190N Galaxy S III mini с поддержкой NFC. Определяется по номеру модели GT-i8190.
Screen flickers after battery replacement
Hi, I my GS3 mini’s battery was on it’s last leg, so I bought a new battery for it. However, it appears that the third party battery I bought was rated for 1350mAh, while the original was 1500mAh. When I run it on the weak original, no flickering. On the new one, flickering. How do I fix this without buying a new phone or yet another battery replacement? (I bought a Samsung Original)
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
@stechkid just based on this "on the weak original, no flickering. On the new one, flickering." replace the battery once more. Get it from a different supplier. This appears to be a power issue due to a "bad" battery. Re-evaluate with a new battery.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
I was just about to buy another original, but then I looked up other solutions and some people were saying that you need to calibrate a new battery, so I used the code and calibrated it and the flickering is gone. I am still going to buy a new battery as I have replaced batteries on other phones, including old Samsungs and this has never happened before, so I am going to buy another from another supplier just in case.
из
The other option to try is recalibration, I was bought another but calibration can fix it in some cases.
Счет 0
Добавьте свой ответ
80stechkid буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 24
За все время: 732
